trashbox
buddypoor wrote on Aug 22nd, 2008, 2:21am:trashbox wrote on Aug 21st, 2008, 10:13pm:Hi buddypoor, Thanks for your reference. It seems good to produce a zero by VCCS instead of esr resistor. Regards, Trashbox Hi trashbox, I know that the paper I have posted is not complete. Therefore I like to add the information, that - as a final conclusion - the paper did propose to place a capacitor across R2 in order to produce a zero in the frequency response of the loop gain. Hi buddypoor, What do you mean it is not completed? My simulation shows it can produce a zero as the paper described though there is some magnitude peaking in frequency response,and these peaking is far away from the poles and zero.
