Oct 31st, 2024, 5:11am
Pages: 1 2
LDO error amplifier selection (Read 15061 times)
trashbox
Re: LDO error amplifier selection
Reply #15 - Sep 07th, 2008, 10:46pm
buddypoor wrote on Aug 22nd, 2008, 2:21am:
trashbox wrote on Aug 21st, 2008, 10:13pm:
Hi buddypoor,
Thanks for your reference. It seems good to produce a zero by VCCS instead of esr resistor. Smiley
Trashbox
Hi trashbox,
I know that the paper I have posted is not complete.
Therefore I like to add the information, that - as a final conclusion - the paper did propose to place a capacitor across R2 in order to produce a zero in the frequency response of the loop gain.
Hi buddypoor,
What do you mean it is not completed?
My simulation shows it can produce a zero as the paper described though there is some magnitude peaking in frequency response,and these peaking is far away from  the poles and zero.
buddypoor
Bremen, Germany
Reply #16 - Sep 8th, 2008, 12:00am
trashbox wrote on Sep 7th, 2008, 10:46pm:
Hi buddypoor,
The text ends abruptly - with other words: the last part of the paper is missing. This is what I ment with "not complete".
trashbox
Reply #17 - Sep 8th, 2008, 7:09pm
Hi buddypoor!
Thanks for your reply. I can download this paper at IEEE TRANSACTIONS ON CIRCUITS AND SYSTEMS—I: REGULAR PAPERS, VOL. 51, NO. 6, JUNE 2004
Trashbox
buddypoor wrote on Sep 8th, 2008, 12:00am:
imd1
Reply #18 - Sep 9th, 2008, 12:51am
trashbox wrote on Sep 8th, 2008, 7:09pm:
Hi buddypoor!
Trashbox
You can just get the final paper from here,
http://amsc.tamu.edu/SIS/Publications/pub/jounal/2004_6.pdf
Pages: 1 2
