Jul 21st, 2024, 2:26am
MOS regime/mode verification (Read 124 times)
Pavel
Lausanne/Switzerland
Aug 21st, 2008, 2:00am
Hello
Is there a sample means to determine functional mode (saturation, conduction) and inversion level (strong/moderate/weak) in spectre/bsim3v3. Under simple means I mean some parameter that could be output rateher in textfile, rather in plot.
Thanks.
Regards.
Pavel.
Istros
Switzerland
Re: MOS regime/mode verification
Reply #1 - Oct 30th, 2008, 3:56am
Hello Pavel,
The parameter "region" gives an estimation on the operating region of a mosfet.
If "region" is equal to:
0 -> transitor is off
1-> transistor is in triode (conduction)
2 -> saturation (in strong inversion)
3 -> subthreshold
4 -> breakdown
Anyway it is quiete easy to determine if a current is in WI, MI or SI. You can use the inversion coefficient, (see Micropower techniques, Vittoz).
Best regards,
Marc
Pavel
Reply #2 - Oct 30th, 2008, 7:58am
Hello Marc
Thanks for response.
For "region" Ok. Concerning inversion level, it requires knowledge of specific current, otherwise calculation. When one has dozens of transistors and wants quickly estimate their inversion level, some "inversion level" parameter would be useful.
Best Regards.
Pavel.
