mitrobgenis
I want to characterize a SD DAC with a bandwitdh from 0 to 1 kHz using spectre. It has a 5-bit internal DAC with differential current output.
For the analog part, in order to measure SNR should I apply a 1 LSB input to the 5-bit DAC and measure the noise? Shall I measure the noise to one current output or in both ? What shall I take as rms value for the signal?
What about Dynamic Range and THD?
