Aug 16th, 2024, 2:43pm
Pages: 1 2 3
passive mixer linearity (Read 22133 times)
kelly
Re: passive mixer linearity
Reply #15 - Feb 10th, 2011, 10:42am
Hi RFICDUDE,
It's 50% duty cycle and down conversion voltage mode mixer.  There is no LC tank on the RF side.  RF side  (matched to 50ohms with real resistors) goes off chip to an attenuator, balum, and a saw.  IF side goes to the gates of an on chip VGA.  I plan to have some caps (~5p) at the mixer output (VGA input) just to have some light filtering.
RFICDUDE
Reply #16 - Feb 10th, 2011, 5:55pm
Hmmm, if it is double balanced and 50% duty cycle LO then I'm not sure why there is excessive LO leakage.
By "DCD" do you mean duty cycle or is this some reference to DC gate bias relative to the LO swing (I'm not exactly sure what you mean by "DCD on the LO")?
kelly
Reply #17 - Feb 10th, 2011, 6:36pm
Hi RFICDUDE,
DCD means duty cycle distortion on the LO, sorry about not being clear about that.
The way is see it is that the DCD of the LO waveform, produce a DC offset of the LO port, therefore, causes the RF feedthrough.
With 0.5% DCD (49.5% duty cycle), I found that the DC of the differential LO is around 9mV.  So I put a DC offset of 10mV on one of the LO sides (with 50% duty cycle), the RF feedthrough is 30dB less that the 49.5% duty cycle with no offset applied.  I wouldn't expect that result.
Is the passive mixer somehow more sensitive to the DCD than just a pure DC offset on the LO?  Or I am looking at this wrong?
Thanks.
RFICDUDE
Reply #18 - Feb 16th, 2011, 3:24am
I understand now.
If the fundamental of the LO is balanced, then you could AC couple the LO to the gates of the mixer devices and bring in a common mode gate bias voltage through high valued resistors. This should prevent DC offset on the LO drive from creating LO feedthrough.
You may still have some Vth mismatch, but it should be much less than 9mV of error.
kelly
Reply #19 - Feb 16th, 2011, 10:52pm
Hi RFICDude,
So I looked at the LO spectrum for 2 cases, LO offset =10mV and LO DCD =0.5%
LO offset =10mV case (no DCD):
LO has a DC component of -40dBC, and odd harmonic LO (LO is a square wave)
RF feedthrough=-60dBc
LO DCD = 0.5% case (no addition offset):
LO has a DC component of -40dBC, now you have both even and odd harmonics of LO (ok, so I guess you get evens 'cause now it's not exactly 50% square wave?)
RF feedthrough=-40dBC (20dB bigger than jus the DC offset case)
So, do the even harmonics introduces addition offset that's why the RF feedthrough is much bigger in the DCD=0.5% case?
Thanks.
RFICDUDE
Reply #20 - Feb 19th, 2011, 5:05am
For your results above, are the LO signals AC or DC coupled to the gates?
kelly
Reply #21 - Feb 19th, 2011, 5:09pm
Hi RFICDUDE,
It's DC.  So the LO goes from 0 to 1V at the gate of the switching devices, and the source/drain are biased 200mV above ground.
When I say I get RF feedthrough, I don't just get RF, I also get what I thought is LO-IF (reverse mixing) and all the higher order ones.  Now I think what I get is actually all the 2nLO+/-RF, eg, LO-IF=LO-(RF-LO)=2LO-RF.
I tried it with the active mixer (which shouldn't have the everse mixing term), but I get the same thing when DCD=0.5% is applied.
Kelly
Kelly
RFICDUDE
Reply #22 - Feb 20th, 2011, 8:32am
Ok, then just AC couple LO and bring in a common mode bias. It should, at least, eliminate switching errors due to LO DCD.
Have you attempted to AC couple the LO?
Reverse mixing is a characteristic of passive mixers. I suppose it is a concern if there are emissions requirements at the mixer input.
kelly
Reply #23 - Feb 20th, 2011, 3:09pm
Hi RFICDUDE,
No, I haven't.  What switching error does AC couple eliminate? Is it just the DC, won't you still have a non-50% duty cycle after the AC couple?
Thanks.
RFICDUDE
Reply #24 - Feb 20th, 2011, 7:38pm
You may benefit a lot from carrying out the analysis yourself.
The LO signal with DCD has some DC imbalance because of the DCD, but if you AC couple the LO then the DC imbalance is not passed on to the gates. Thus the LO DCD contribution to carrier feedthrough should be eliminated (i.e. you should be able to increase DCD without seeing a strong sensitivity to LO feedthrough).
kelly
Reply #25 - Feb 21st, 2011, 1:10am
hi RFICDUDE,
So I AC coupled the LO signal.  If I looked at the dft of LO before and after the AC, the DC component decrased by >30dB.  But the even harmonics are still present in both signals.  So as a result, I still get all the 2nLO+/-RF components at the IF outputs including RF for n=0.
Do you expect the duty cycle distortion causes the even harmonics on the LO ?
Thanks.
aaron_do
Reply #26 - Feb 21st, 2011, 5:34am
Hi Kelly,
can I confirm a few things with you?
1) this is a double-balanced design.
2) you have a square wave drive.
3) by 0.5% DCD, you mean that the positive LO is driven with 50.5% duty cycle, and the negative LO is driven with 49.5% duty cycle (or vice-versa).
In a double-balanced design, the DCD on the LO would cause a common-mode LO leakage to the RF ports, so I'm not sure if it would propagate to the IF ports (as a differential signal). In a single-balanced design, I would definitely expect to see all the tones that you are seeing with any DCD.
Also, I'm not so sure if your use of a DC offset to represent the DCD is correct. If it is a square wave, then the switches will take on only two states: ON or OFF. A 9 mV DC signal is not likely to have that much effect on whether a switch is ON or OFF (when it is driven by a large square wave). However, a change in the duty cycle directly affects how long the switch is ON/OFF.
I'm sorry if I have misunderstood your circuit. Perhaps it would be more clear with a schematic.
cheers,
Aaron
kelly
Reply #27 - Feb 21st, 2011, 10:09am
Hi Aaron,
Yes, you understand the circuit correctly.  What you and RFICDUDE describing is what I expect to see but I don't from my simulations.  Maybe I am doing something wrong, just can't figure it out.  To answer your question,
1.  yes. I use vcvs to do the single to diff on both LO and RF.  This is just a single mixer,  no I/Q path.
2. yes.
3. yes.  specifically, I use a Vpulse source, the pulse width is 1/flo/2.02-rtime ( flo=lo frequency, rtime= rise time=fall time) for DCD=49.5.  It's 2 for 50% duty cycle.  I then use the two vcvs to do the single to diff for both LO ports.
I agreed with what you said about the LO/RF leakage.
I am not using DC offset to model DCD.  In fact, if I just use the DC offset=10mv , the RF feedthrough is not that much (as you pointed using the square wave) and there is no 2nLO+/-RF at the IF output.
I use the vpulse decribed above to model DCD and I see both DC and even harmonics tones on LO.  What I don't understand is why I am seeing all the 2nLO+/-RF on the IF output when I model the DCD the way I did.
Thanks.
kelly
Reply #28 - Feb 21st, 2011, 10:12am
sorry when I say IF output I mean IFP-IFN, so it's a diff output
vp1953
Reply #29 - Feb 21st, 2011, 12:29pm
Hi Kelly,
If i got this right, you have a double balanced mixer with complementary LO signals(call it LO+, LO-) driving the LO ports. When the duty cycle of LO+ and LO- are changed say to 50.5 and 49.5, you are seeing 2n.LO+RF?
I would absolutely expect to see even harmonics of LO for the above scenario; when LO+ and LO- are perfectly complementary, the DC and the even harmonics get cancelled out. When there is slight difference in duty cycles, there is incomplete cancellation of even harmonics and a direct RF feedthrough.
Pages: 1 2 3
