kelly
Hi Aaron,
Yes, you understand the circuit correctly. What you and RFICDUDE describing is what I expect to see but I don't from my simulations. Maybe I am doing something wrong, just can't figure it out. To answer your question, 1. yes. I use vcvs to do the single to diff on both LO and RF. This is just a single mixer, no I/Q path. 2. yes. 3. yes. specifically, I use a Vpulse source, the pulse width is 1/flo/2.02-rtime ( flo=lo frequency, rtime= rise time=fall time) for DCD=49.5. It's 2 for 50% duty cycle. I then use the two vcvs to do the single to diff for both LO ports.
I agreed with what you said about the LO/RF leakage.
I am not using DC offset to model DCD. In fact, if I just use the DC offset=10mv , the RF feedthrough is not that much (as you pointed using the square wave) and there is no 2nLO+/-RF at the IF output. I use the vpulse decribed above to model DCD and I see both DC and even harmonics tones on LO. What I don't understand is why I am seeing all the 2nLO+/-RF on the IF output when I model the DCD the way I did.
Thanks.
