Aug 16th, 2024, 2:29pm
Pages: 1 2 3
passive mixer linearity (Read 22132 times)
aaron_do
Aug 21st, 2008, 9:12pm
generally for a passive mixer, we can improve the conversion gain and to a certain degree the noise performance by lowering the duty cycle. THis is generally done by reducing the DC gate bias of the switching FETs.
Supposedly this leads to poorer linearity as the high order LO harmonics will be more prevalent. However, IMO it seems that the harmonic generation of the input signal should be smaller since when the DC gate bias of the FET is reduced, the device is ON for a shorter time and hence covers a smaller operation region.
Any thoughts on this?
nxing
God help the person
who help themselves
China
Re: passive mixer linearity
Reply #1 - Aug 26th, 2008, 5:27pm
Hi aaron_do,
Can you tell some details why reduce the cycle can actually increase the gain? actually, I am thinking that if the duty cycle is reduce, the gain will be less than 2/pi.
nxing
aaron_do
Reply #2 - Aug 27th, 2008, 2:18am
Sure. You can find this in several papers on passive mixers btw.
The switch is a variable resistor. Its resistance can be expressed in a fourier series, so it has a DC component and an AC component.
Supposed a voltage is applied to the input at RF. This voltage will be converted into an IF signal by the first order component of the resistance. It will then reach the output and the load will be the zeroth order component. So overall you will get an equation which has the term G1/G0, where G1 is the first order component of the conductance and G0 is the zeroth order component. G1/G0 is dependent on the duty cycle, where a smaller duty cycle results in a high G1/G0. Note that G is zero when the transistor is off. Therefore a longer off time results in a smaller G0.
The gain can reach a maximum value of 1 (0 dB). You will find a similar result in "A 12-mW Wide Dynamic Range CMOS Front-End for a Portable GPS Receiver" by Arvin R. Shahani, Derek K. Shaeffer, and Thomas H. Lee.
If you actually try and write out the equations you will find it a little more difficult than what i've tried to explain.
cheers,
Aaron
RFICDUDE
Reply #3 - Aug 27th, 2008, 6:58pm
You asked for thoughts ..
It seems as the duty cycle reduces the mixer is approaching an ideal impulse sampler as opposed to the natural sampling you get with 50% duty cycle. This explains the increased LO harmonic content as the switching aliases approach unity in respect to the input for ideal impulse sampling.
I suspect, but don't know for sure, that the degraded linearity originates from distortion during the rise/fall times of the switches. This becomes a greater percentage of the overall signal passed through the mixer, so the significance of the rise/fall and settling time impacts the desired signal more.
Just a guess/thought.
aaron_do
Reply #4 - Aug 27th, 2008, 7:39pm
thanks. I hadn't even considered that at all...
Aaron
Poojan Wagh
Reply #5 - Aug 28th, 2008, 5:17pm
aaron_do wrote on Aug 27th, 2008, 2:18am:
cheers,
Aaron
If you're doing a double-balanced switch-mode mixer, the usual analysis assumes you are multiplying with a +/- 1 square/rectangular signal. The first order harmonic of this pulse signal is given by:
2/pi * sin(pi * d)
where d is the duty ratio. The maximum conversion gain is given by d=50% (conversion gain of 2/pi, or -4 dB).
aaron_do
Reply #6 - Aug 28th, 2008, 7:36pm
thanks. Actually i am aware of that analysis too. Perhaps you could read the paper I mentioned (very good passive mixer analysis) in the previous post or maybe run some simulations with changing bias point. Personally, my own simulations agree that the maximum conversion gain is 1.
The paper I mentioned also concluded that a sine-wave drive gives a better conversion gain than a square-wave drive...
cheers,
Aaron
kelly
Reply #7 - Jan 20th, 2011, 10:05pm
Hi Aaron,
I looked up the paper by TLee as you mentioned.  I didn't see the analysis,  Perhaps, I missed it?
A lot of  the passive mixer paper analysis is for the I/Q mixers (by having non-overlapping clocks, you actually don't lose current or no two voltages are on at the same).  But I assume the same principle apply even if you just have a single voltage mode passive mixer, right?
My problem is, I actually see this in the simulation (I have only one mixer in voltage mode), but I can't explain it.
Could you explain your G1/Go ananlysis again?
Thanks much.
aaron_do
Reply #8 - Jan 21st, 2011, 5:06am
Hi Kelly,
I'm pretty sure there's an analysis there. Anyhow, if you're interested in my own analysis, then you could read the following paper:
A. V. Do et. Al, "An Energy-Aware CMOS Receiver Front End for Low-Power 2.4-GHz Applications", IEEE Transactions on Circuits and Systems I, vol. 57, no. 10, Oct 2010, pp. 2675-2684.
Read section IVB and the Appendix. You could also refer to a book (I can't exactly remember the title) by Stephen A. Mass about nonlinear microwave design.
cheers,
Aaron
kelly
Reply #9 - Jan 23rd, 2011, 2:18pm
got it, thanks.  I must have gotten the pre-journal (short paper) version of it the 1st time I searched (the text was only 1 page).
I guess maybe another way to see why IIP3 degrades is that the mixer has a higher average impedance for the 25% LO duty cycle vs the 50% case.
Thanks.
kelly
Reply #10 - Feb 3rd, 2011, 11:55pm
Hi All,
I have a stupid question, won't the 25% duty cycle causes a huge RF feedthtrough?  Am I not thinking this right?
RFICDUDE
Reply #11 - Feb 5th, 2011, 11:15am
Not if the architecture remains double balanced.
kelly
Reply #12 - Feb 6th, 2011, 1:53am
oh, yeah, thanks.  I forgot that the 25% duty cycle is non-overlapping, so the DC is still 0.  Which is different from the normal duty cycle distortion case.
kelly
Reply #13 - Feb 8th, 2011, 2:18pm
I am looking at the RF feedthrough as a function of the DCD on LO.  It seems that it's very sensitive (-35dBc for a 49.5% or55.05% DCD).  Does anyone see the same thing?  By the way, this is just a single mixer not a IQ modulator.
Thanks.
Kelly
RFICDUDE
Reply #14 - Feb 9th, 2011, 5:25pm
Is the single mixer operating from a 1/4 duty cycle LO?
If so, is there a RF LC tank circuit on the RF side?
What is the load on the baseband side?
Pages: 1 2 3
