Aug 15th, 2024, 7:58am
How to use bsource in spectre? (Read 16886 times)
microant
China,SH
Aug 24th, 2008, 8:28pm
I want to use behavior model in cadence spectre, I found the help said that it can use bsource to achieve. well, I didn't find any instance in analogLib library can set the bsource attribute, would anyone can give me some suggestion?
thanks!
BR,
microant
Re: How to use bsource in spectre?
Reply #1 - Aug 24th, 2008, 10:42pm
Never use the bsource. Learn and use Verilog-A. It will serve you much better in the long run.
achim.graupner
Reply #2 - Aug 25th, 2008, 1:05am
Hi there,
1. Ken is right.
2. for the quick hack in schematic in analogLib you have  {voltage; current} controlled {voltage; current} source: vcvs, ccvs, cccs, vccs. Do not try to model much more that a simple buffer - the schematic gets weired quickly soon.
Achim Graupner
ZMD AG, Dresden, Silicon Saxony, Germany
microant
China,SH
Reply #3 - Aug 25th, 2008, 4:51am
thanks for above!
But how to realize the following function in spectre such as in hspice?
E1 a b vol=v(n1,n2)*k max=cc min=0
Verilog-A is so strong while if the expression quote many voltage or current it need many input/output port.
BR,
microant
Reply #4 - Aug 25th, 2008, 5:40am
microant wrote on Aug 24th, 2008, 8:28pm:
Many simulators except for Cadence Spectre had enhanced controlled sources which were familiar in HSPICE or PSPICE.
Also many model files provided from foundary are written in HSPICE netlist.
So "bsource" was introduced into Cadence Spectre for porting HSPICE model file which includes enhanced controlled sources.
So Cadence doesn't provide spectre view of bsource.
But you can use bsource in netlist.
See the result of "spectre -h bsource".
Actually any bsources are replaced to Verilog-A internally in Cadence Spectre.
microant wrote on Aug 25th, 2008, 4:51am:
See http://www.designers-guide.org/Forum/YaBB.pl?num=1188726802/0
« Last Edit: Aug 25th, 2008, 7:50pm by pancho_hideboo »
microant
China,SH
Reply #5 - Aug 25th, 2008, 7:19pm
Hi pancho_hideboo
thanks for your suggestion!
I find a alternative method to use bsource in spectre not by modifying the netlist.
copy instance 'vdc' from analogLib and modify the CDF parameter.
in simulation information, modify the item 'componetName' with bsource, in component parameters, add new param 'v', 'max_val' et, delete other params.
when use bsource, just like add voltage source and fill the expression in param 'v' and when generate netlist, it will be
v1 net1 net2 bsource v=express
BR,
Lin
Reply #6 - Aug 28th, 2008, 7:33am
I recommend that you start with this ...
`include "disciplines.vams"
module clamp (pout, nout, pin, nin);
output pout, nout;
input pin, nin;
electrical pout, nout, pin, nin;
parameter real gain=1;
parameter real minimum=0;
parameter real maximum = 1 from (minimum:inf);
real in;
analog begin
    in = V(pin, nin);
    if (in > maximum) in = maximum;
    if (in < minimum) in = minimum;
    V(pout,nout) <+ gain*in;
Reply #7 - Aug 28th, 2008, 1:32pm
Ken -
Shouldn't you do
   out = gain * V(pin, nin);
   if (out > maximum) out = maximum;
   if (out < minimum) out = minimum;
   V(pout,nout) <+ out;
Not that either one is good for convergence, but I don't quite know what your maximum was doing.
Reply #8 - Aug 29th, 2008, 3:58am
Geoffrey,
   Indeed, the model should be ...
output pout, nout;
input pin, nin;
real out;
analog begin
    out = gain*V(pin, nin);
Why do you think convergence will be a problem?
Reply #9 - Aug 29th, 2008, 7:05am
Ken Kundert wrote on Aug 29th, 2008, 3:58am:
I was thinking that, when it's clamping, there is no derivative information, so the linear solver wouldn't "know" to change the input voltage to fix the output.  I suppose, though, that it looks like an independent voltage source in that case, so it isn't a problem.
imd1
Reply #10 - Sep 1st, 2008, 1:11am
How about the discontinuous jump in the derivative when the hard limiter kicks in ?
i mean, the solver is doing its N-R iterations and using the derivative to "slide towards" the circuit solution at the node. If the solution is just below the hard limit breakpoint and the current estimate is above that level, there's no gradient information to point in which direction to go.
I assume that a smoothing function would be useful . Comments?
Reply #11 - Sep 1st, 2008, 6:53pm
A common misconception.
imd1
Reply #12 - Sep 2nd, 2008, 1:17am
Ken Kundert wrote on Sep 1st, 2008, 6:53pm:
I see.
