microant wrote on Aug 24th, 2008, 8:28pm:I want to use behavior model in cadence spectre, I found the help said that it can use bsource to achieve. well, I didn't find any instance in analogLib library can set the bsource attribute
Many simulators except for Cadence Spectre had enhanced controlled sources which were familiar in HSPICE or PSPICE.
Also many model files provided from foundary are written in HSPICE netlist.
So "bsource" was introduced into Cadence Spectre for porting HSPICE model file which includes enhanced controlled sources.
So Cadence doesn't provide spectre view of bsource.
But you can use bsource in netlist.
See the result of "spectre -h bsource".
Actually any bsources are replaced to Verilog-A internally in Cadence Spectre.
microant wrote on Aug 25th, 2008, 4:51am:But how to realize the following function in spectre such as in hspice?
E1 a b vol=v(n1,n2)*k max=cc min=0
Verilog-A is so strong while if the expression quote many voltage or current it need many input/output port.
See
http://www.designers-guide.org/Forum/YaBB.pl?num=1188726802/0
