Aug 15th, 2024, 10:25am
Pages: 1 2
.pss Simulation Results Vary in Different runs in Cadence (SpectreRF) (Read 4207 times)
Maryam
Re:  .pss Simulation Results Vary in Different runs in Cadence (SpectreRF)
Reply #15 - Sep 06th, 2008, 5:23pm
By the way, in general, the pss simulation of my circuit does not always converge. I keep simulating it several times and change the integration methods (mostly default, gear2, gear2only and sometimes trap and traponly) until I get convergence.
Reply #16 - Sep 6th, 2008, 10:05pm
Maryam wrote on Sep 6th, 2008, 5:19pm:
Yes, the results were different in these two cases,
in terms of the duty cycle of transistors being in triode and the amplitude of the voltages.
I can't believe that remarkable discrepancies exist although convergence succeed with reasonable ConvNorm.
Show me result's graph which show discrepancy with each ConvNorm.
I simulated a transient with moderate settings; the results were fine.
Make your issues correct and clear.
(1) Transient Analysis of errpreset=liberal --->> unreasonable results
(2) Transient Analysis of errpreset=moderate --->> reasonable results
(3) Transient Analysis of errpreset=conservative --->> reasonable results
(4) PSS Analysis of errpreset=conservative --->> often give unreasonable results
From your description I understand that transient(moderate) analysis give reasonable results while pss analysis often give unreasonable results.
Is this correct ?
How about PSS(moderate) with all default setting ?
Compare two cases, transient(moderate) and pss(moderate).
Is there remarkable difference between two ?
Maryam wrote on Sep 6th, 2008, 5:23pm:
Try to use Harmonic Balance PSS not Shooting Newton PSS.
Maryam
Reply #17 - Sep 6th, 2008, 11:14pm
(1) Transient Analysis of errpreset=liberal --->> totally unreasonable results (different operating regions for the transistors)
Although it took a long time for the two transients to settle so I didn't compare the exact steady state magnitude of cases 2 and 3, but the results reasonably agreed.
(4) PSS Analysis of errpreset=conservative --->> the results don't agree. Usually they were close, in some cases they were different by about 0.2V difference in amplitude, and in a few cases, I got totally different results.
By changing the design parameters, I face different situations, so I cannot generate the same big discrepancy now since I have changed the design parameters.
"From your description I understand that transient(moderate) analysis give reasonable results while pss analysis often give unreasonable results.
Is this correct ?"
Yes. However, since the transient analysis takes a very long time to simulate and settle, I don't run it that often. So, I cannot say that I always get the exact same result from moderate and conservative transient. But, so far I didn't get unreasoonable results from transient if it converged.
"Try to use Harmonic Balance PSS not Shooting Newton PSS."
I thought Spectre uses Shooting method and ADS uses harmonic balance.
Can I do harmonic balance in Spectre?
Thank you very much.
« Last Edit: Sep 7th, 2008, 3:04am by Maryam »
Reply #18 - Sep 6th, 2008, 11:20pm
Maryam wrote on Sep 6th, 2008, 11:14pm:
Usually they are close, in some cases they are different by about 0.2V difference in amplitude,
When you see large diffences, does PSS converge with small ConvNorm truely ?
I think you are missing any caution or message in Spectre's logfile.
Anyway your circuits is difficult in convergence with Shooting Newton PSS.
Try to use Harmonic Balance PSS.
If a sinusoidal input signal is large enough near or over gain compression point,
Shooting Newton PSS often doesn't converge at all on the contrary to Cadence advertisement of Shooting Newton PSS.
I've never used SpectreRF mainly for RF circuit.
http://www.designers-guide.org/Forum/YaBB.pl?num=1162921214/0#0
http://www.designers-guide.org/Forum/YaBB.pl?num=1170364605/2#2
http://www.designers-guide.org/Forum/YaBB.pl?num=1194765058/1#1
http://www.designers-guide.org/Forum/YaBB.pl?num=1208334972
I have many simulators working on Cadence ADE, so I don't have to insist on Cadence SpectreRF at all.
If you have other simulators such as ADS, GoldenGate, HspiceRF, SmartSpiceRF, EldoRF, etc., try other simulators.
Maybe you will get far good simulation performance than Cadence Spectre.
http://www.designers-guide.org/Forum/YaBB.pl?num=1210062036
Yes, Cadence Spectre have Harmonic Balance Analysis since Version 6.0USR1.
See the following.
http://www.designers-guide.org/Forum/YaBB.pl?num=1125929808
http://www.designers-guide.org/Forum/YaBB.pl?num=1205223090
« Last Edit: Sep 7th, 2008, 1:50am by pancho_hideboo »
Maryam
Reply #19 - Sep 7th, 2008, 3:02am
"When you see large diffences, does PSS converge with small ConvNorm truely ?"
The two cases of which I attached log file, had different results, while at the last step, conv norm wassmaller than 1.
As far as I know, for circuits with large amplitudes and switching behavior of the transistors, actually HB has convergence difficulty (the extreme case is having logic gates).
1) liberal pss (default setting) did not converge at all.
2) moderate pss (default setting) converged and the discrepancy between the results was larger than conservative pss .
3) conservative pss (default setting) converged and had inconsistent results.
4) liberal transient converged. I could get consistent results with default settings this time  while before it did not give reasonable results!!
5) moderate transient (default setting) gave consistent results.
6) conservative transient (default setting) gave consistent results.
The results of cases 5 and 6 (moderate transient and conservative transient) agreed.
Reply #20 - Sep 7th, 2008, 5:36am
Maryam wrote on Sep 7th, 2008, 3:02am:
No. What you know is just same as Cadence advertisement.
And current HB analysis of Agilent ADS or GoldenGate is very robust.
If an input signal or output signal are pulse-shaped wave having sharp edge, shooting newton is superior than HB analysis.
But if an large sinusoidal input signal is added to amplifier input, for example, for evaluation of gain compression of amplifier, shooting newton can't converge at all while HB analysis can converge.
I can't evaluate gain compression characteristics using Shooting Newton PSS of Cadence Spectre.
For common classical RF evaluation cases where sinusoidal signal drive are used, Shooting Newton PSS of Cadence Spectre is inferior than HB analysis.
And I always encounter convergence problem of Shooting Newton PSS of Cadence Spectre.
SpectreRF can work for simple circuits which behave gently and is not robust at all for actual circuits on the contrary to Cadence Advertisement.
In your case, shooting newton PSS with any errpreset can't be reliable.
Anyway try HB analysis of Cadence Spectre or other RF simulator.
« Last Edit: Sep 7th, 2008, 4:36pm by pancho_hideboo »
Pages: 1 2
