Jul 23rd, 2024, 5:13am
accuracy of cyclic TDC (Read 1502 times)
smarty
Sep 04th, 2008, 9:51am
Hi All,
I am first time working on a cyclic TDC ( time to digital converter) where I have as input a pulse which shrinks by a value per cycle and the output is an 8 bit digital code. I use a 8-bit ripple counter to measure the generated code.
Can anybody sugguest how should I measure the accuracy of this TDC using Spectre.
Thanks and Regards,
SBR
View Profile smarty smarty   IP Logged
