Jul 22nd, 2024, 3:34pm
Pages: 1 2
Intergrator Chopping Problem (Read 11744 times)
Berti
Re: Intergrator Chopping Problem
Reply #15 - Sep 19th, 2008, 6:53am
Frank, the ideal gain-boosting you simulated: Is it single-ended or differential?
frank007
Reply #16 - Sep 20th, 2008, 3:48pm
Berti wrote on Sep 19th, 2008, 6:53am:
It's differential.
Berti
Reply #17 - Sep 21st, 2008, 11:27pm
I was just thinking that the chopper might add charge injection which together will low CMRR affects the output signal. Differential gain-boosting would increase the CMRR. But since you do an ideal simulation (without mismatch) my idea is probably wrong.
Cheers
Pages: 1 2
