Aug 16th, 2024, 1:23am
NC elaboration error (Read 2208 times)
godfather
Sep 08th, 2008, 11:39am
I encountered following error
Error encountered during NC elaboration for configuration VFS_AMS_PHY180_sims.aeq_ac_sim:config_ams
while running AMS example.
what shall i do to remove the error.
Riad KACED
Swindon, UK
Re: NC elaboration error
Reply #1 - Sep 16th, 2008, 10:15am
The descrption of your problem is insuffufient for any investigation I'm afraid. I guess you are using AMS from HED, don't you ?
It would be helpful if you come with the error messages as they are dumped into the HED. The message you've posted is just the last one which actually not that helpful for debug ...
BTW, It would be great to mention your ius version as well:
UNIX> ncvlog -VERSION
Cheers,
Riad  ;)
Riad KACED
PDK, EDA Support Engineer.
