Jul 20th, 2024, 1:24am
what does vstat mean in hspice log file (Read 826 times)
hzfeiyun
Sep 11th, 2008, 12:31am
one transistor (w/l=80/2) op results:
           0:mi100
           0:n18
region    cutoff
id           1.99u
vgs         425m
vds         859m
vbs         -342m
vth         507m
vdsat       37m
vod          -81m
beta         21m
gm           60u
gds           160n
gmb          15u
Q1:from textbook, vdsat (saturation voltage) = vgs -vth, but, obviously, it has different meanings here. What does it mean?
Q2:this transistor is a input tran of an OPAMP, should it be working on saturation region? any problem if it works on cut-off region evan pass all simualtion?
Thx. Wink
Re: what does vstat means in hspice log file
Reply #1 - Sep 11th, 2008, 12:58am
Hi hzfeiyun,
You may call it cut-off region or weak inversion region. There are specific description on MOS transistors in weak inversion region in the textbooks like [Grey and Meyer] .
The vdsat is still saturation voltage although it is not equal to vgs-vth in weak inversion region. Smiley
Best regards,
Yawei
hzfeiyun
Re: what does vstat mean in hspice log file
Reply #2 - Sep 11th, 2008, 1:05am
ywguo wrote on Sep 11th, 2008, 12:58am:
Hi hzfeiyun,
Best regards,
Yawei
i found some transistor's vdsat is not equal to its vod even in saturation region
and, what does vsat mean in cut-off region?
Reply #3 - Sep 11th, 2008, 2:54am
What is vod? Do you mean vgs-vth? Since the popular BSIM3 model is more complicated than level-1 MOS model, vdsat is not equal to vgs-vth strictly. Please refer to BSIM3 manual which is available at Berkeley website bsim.eecs.berkeley.edu.
In weak inversion region, the MOS operates like a bipolar transistor much more. When the vds is greater than vdsat, the Ids is very flat. In other word, the MOS is in saturation region.
In [Grey and Meyer], it states that the drain current is almost constant when Vds>3VT (VT=kT/q). So the minimum vds required to force the transistor to operate as a current source in weak inversion is independent of the overdrive. At 300K, 3VT ≈75 mV. That is a relative coarse but reliable value. It is not uncommon to get vds = 37mV as that in your SPICE log file.
Best regards,
Yawei
