Jul 20th, 2024, 3:10am
How to simulate chopping amp with hspice? (Read 4540 times)
trashbox
Sep 10th, 2008, 12:34am
How to simulate chopping amplifier's ac characteristic such as frequency response, noise performance with hspice or eldo? There are many swithes in the signal path.
Thanks!
Trashbox
Frank Wiedmann
Munich, Germany
Re: How to simulate chopping amp with hspice?
Reply #1 - Sep 10th, 2008, 4:41am
No idea how to do it with Hspice or Eldo, but http://www.designers-guide.org/Analysis/sc-filters.pdf shows how to do it with SpectreRF.
HdrChopper
Reply #2 - Sep 10th, 2008, 5:09am
In Frank's reference you will find the best way to do it is by means of a pss + pac analysis. This analysis basically consider the two different operating points of your circuit corresponding to each chopper phase. In this way you will be able to see the resulting modulated offset in the frequency domain and all the associated effects of the chopper operation.
Nevertheless a fist basic (and effective) approach to sizing your circuit from the ac requirements perspective can be perfectly done with the standard ac analysis.
Tosei
Keep it simple
trashbox
Reply #3 - Sep 10th, 2008, 7:06pm
Hi tosei and Frank,
Thank for your suggestion.
Hi tosei,
Do you agree that there is no difference about  the phase margin between with and without chopping switches for an amlifier?
Trashbox
HdrChopper wrote on Sep 10th, 2008, 5:09am:
Tosei
Tlaloc
Dallas, TX
Reply #4 - Sep 10th, 2008, 8:11pm
If the network doesn't change between the two phases of the chopping switches, then the phase margin of the amp would remain the same.  However, the switches will add additional resistance, which, if not sized correctly could slow the entire loop.
HdrChopper
Reply #5 - Sep 11th, 2008, 7:29pm
I agree the PM will be the same with or without the chopper being active, if - as Tlaloc suggested - you analyze the stability for the non-chopped amplifier with the switches in place to account for their contribution to the phase response. Most of the cases such contribution is negligible.
Tosei
Keep it simple
