tempora123
Thanks for your replies. - About stb analysis, I've tried it and I get the same results as in my ac analysis with opening/closing the loop. I can live with tran analysis results I guess because I don't think now it is possible to simulate this circuit properly with any small signal analysis. - About thd formula in pss, the aproach mentioned works ok, I get a formula: _drplPssThd(v("/out" ?result "pss_fd") 10000) but it works (prints results) fine only if used in one corner simulation. If I run many corners and try to plot the results I get: *Error* awvfPlotDoubleWave: not a waveform - nil *Error* drfGetWaveformXVec: not a waveform - nil If trying to print: *Error* no value at 1 , please check your entry at 'Print At' form (in one corner simulation it shows thd vs index from 1 to 10) However, when using printvs it shows: *Error* X axis not numbers, can't print a portion of it but prints the results. I guess I can live with that for the moment. But I would like to know how to properly format this formula so that it works with no errors. Any ideas are welcome. Thanks.
Regards, L.S.
