Jul 17th, 2024, 12:28am
report a bug: laplace function does not support ac analysis (Read 2912 times)
nus_lin
Sep 22nd, 2008, 6:16am
hello, guys.
i just found that if any branch is defined by laplace function, then its contribution will be ignored during ac analysis. can you tell me how to solve this problem?
example:
`include "constants.vams"
`include "disciplines.vams"
module S_gm(Vi,Vo);
 inout Vi,Vo;
 electrical Vi,Vo;
analog begin
V(Vo) <+ laplace_np(V(Vi),{1},{-p1,0});
Re: report a bug: laplace function does not support ac analysis
Reply #1 - Sep 22nd, 2008, 6:44am
It works fine for me. For a simple example
a constant term and frequency dependent
term got the attached results with the following
code
module test(Vi,Vo);
inout Vi,Vo;
electrical Vi,Vo;
parameter real p1=1 ;
analog begin
I(Vo) <+ 0.001 * laplace_np(V(Vi),{1},{-(2*`M_PI*p1),0});
I(Vo) <+ 0.001 * V(Vi) ;
nus_lin
Reply #2 - Sep 22nd, 2008, 7:06am
hi, sheldon, thank you. i tried your code too, but it doesn;t work in my machine. may i ask which design tools do you use?
Reply #3 - Sep 30th, 2008, 12:53am
Nus_lin,
  Spectre
