Jul 17th, 2024, 12:33am
How to introduce delay within conditional statement? (Read 1444 times)
vpen
Philippines
Sep 26th, 2008, 7:10am
Hi everyone! please help. Cry... I want to introduce a delay within a conditonal if statement using Verilog-A.
My target code should function something like this:
if ( comp_flag == 1 )
          I( VOUT, GND ) <+ transition( 0.0, rdelay);
else
          V( VOUT, GND ) <+  transition( 0.0, fdelay);
but since its illegal to put transition() inside if conditons
i modified my code like below
   I(iout) <+ transition( 0.0, rdelay);
   V(vout) <+ transition( 0.0, fdelay);
          I( VOUT, GND ) <+  I(iout) );
else
          V( VOUT, GND ) <+  V(vout) );
The code has no error at compilation but the delay was not
accounted in the simulation?
What could be wrong with the code?
or
what alternative should i use? Cry Cry Cry
Re: How to introduce delay within conditional statement?
Reply #1 - Sep 26th, 2008, 10:45am
In your modified version, are "vout" and "VOUT" distinct?  Verilog-A is case-sensitive, but I'm not sure whether you were careful when excerpting your model.
I'd add two new nodes:
 electrical int_iout, int_vout;
and contribute both like this:
 I(int_iout) <+ V(int_iout) + transition( 0.0, rdelay);
 I(int_vout) <+ V(int_vout) + transition( 0.0, fdelay);
then
 if (comp_flag == 1)
   I(VOUT, GND) <+ V(int_iout);
 else
   V(VOUT, GND) <+ V(int_vout);
The internal nodes have 1-Ohm resistors on them that convert the current into a voltage; there are funny tricks when you both contribute and probe I(iout) as in your code.  In mine, the probe is always V(x).
Oh, and I assume the "0.0" first arg of transition() is just a dummy, you actually have something that changes there.
