In your modified version, are "vout" and "VOUT" distinct? Verilog-A is case-sensitive, but I'm not sure whether you were careful when excerpting your model.
I'd add two new nodes: electrical int_iout, int_vout; and contribute both like this: I(int_iout) <+ V(int_iout) + transition( 0.0, rdelay); I(int_vout) <+ V(int_vout) + transition( 0.0, fdelay); then if (comp_flag == 1) I(VOUT, GND) <+ V(int_iout); else V(VOUT, GND) <+ V(int_vout);
The internal nodes have 1-Ohm resistors on them that convert the current into a voltage; there are funny tricks when you both contribute and probe I(iout) as in your code. In mine, the probe is always V(x).
Oh, and I assume the "0.0" first arg of transition() is just a dummy, you actually have something that changes there.
