Jul 17th, 2024, 12:27am
Critical Question (Read 3522 times)
godfather
Critical Question
Sep 26th, 2008, 1:26pm
Hello all,
This is struggling in my mind,
whats the difference between verilog, verilog-A,verilog-ams,vhdl,and vhdl-ams.
Re: Critical Question
Reply #1 - Sep 29th, 2008, 4:58am
Verilog was IEEE standard 1364.  It has now been subsumed by IEEE std 1800, SystemVerilog.  Verilog is a hardware description language -- essentially a programming way to describe an electronic circuit you are trying to design/build/simulate.
Verilog-A was an analog behavioral language syntactically based on Verilog; it was subsumed (made an official subset) of Verilog-AMS, which is an Accellera standard.  (Accellera plans to donate this to the IEEE at some point.)
VHDL (IEEE std 1076) and VHDL-AMS (1076.1) are a "rival" hardware description language and its analog and mixed-signal extensions.
godfather
Reply #2 - Sep 29th, 2008, 12:25pm
thnks for the reply. one quick question so can you build a ripple carry adder in verilog ams and if so then whats the difference between that building in system verilog and verilog ams.
Reply #3 - Sep 30th, 2008, 1:53pm
You can build the adder in Verilog, and both SV and V-AMS are supersets of Verilog, so you can do it in either, and there should be no difference.
jbdavid
Reply #4 - Oct 4th, 2008, 12:22am
This has probable been stated here - and other places - several times.. did you try to search for an answer first?
Verilog started as a language to describe and verify LOGIC - iow DIGITAL.
Verilog-A is a similar language to describe ELECTRICAL/Conservative systems that can be represented as Lumped Element models.. (R, L, C, transistors etc.. this supports some other physical domains including MAGNETIC, and Positional, which make it very useful to model things that need to work with logic like amplifiers and MEMS accelerometers.  Verilog-A as a subset is becoming the primary language to define "compact models" of devices (think BJT, MOS3 or BSIM4) allowing a single definition to be compiled into many simulators including GNUCAP, Spectre, and Hspice..
Verilog-AMS is a superset of Verilog and Verilog-A, also adding some features to support automating the connections between logic and electrical, as well as allowing full interaction between electrical things and digital things
VHDL is a hardware description language that supports many sorts of system level design, including both logic and some analog systems.. but did NOT have any support for solving analog dynamic systems (ie in terms of derivatives or integrals.. ) on the other hand real numbers have been well supported, even allowing one to define a wire that carries a "record" containing several real numbers.
VHDL-AMS added dynamics support to VHDL, but there is no VHDL-A subset. thus leaving it unsuitable for compact modeling.
SystemVerilog adds some system level constructs to Verilog, (ie real numbers, and "structures" ) as well as an assertion language to support digital verification. -- oops sorry you didn't ask about that did you.
Its a complicated world.. good luck.
jbd
jbdavid
godfather
Reply #5 - Oct 8th, 2008, 10:15pm
thnks all for amazing replies.......... but the real thing is to design in mixed signal....  ::)
