Jul 17th, 2024, 12:27am
[Q] Verilog-A Modeling (Read 1824 times)
kidhyun
Oct 06th, 2008, 5:25pm
   In a test bench for circuit, I added Verilog-A block which does only
>   parameter real offset = 0;
>   analog
>            V(out) <+ V(in) + offset;
   ,where the offset is by default set to 0 in my simulation.
   (I inserted this block in some place in the circuit)
   I assumed that this block would not make any difference in the simulation result.
   But when I checked the spectrum (using psd) there was significant difference between results with and without this block.
   Just the existence of this block affect the time step in solving the node equations?
Thank You
jbdavid
Re: [Q] Verilog-A Modeling
Reply #1 - Oct 6th, 2008, 9:37pm
I'm going to go out on a limb here, and GUESS that by
"without" this circuit, you just had a wire ?
which would mean that you would have had a voltage, and, as needed current along that wire..
with this module you have, effectively an ideal VCVS with the control voltage being the input + offset..
Quite a different thing than
V(in,out) <+ offset;
which defines a branch between in, and out, with a fixed voltage (maybe 0) leaving its current unconstrained.. which will behave MUCH more like a wire..
HTH.
jbdavid
kidhyun
Reply #2 - Oct 6th, 2008, 11:51pm
Thank you. I think I made a mistake there. It works fine now.
