Jul 16th, 2024, 5:35pm
PSS Simulation of mtline (Read 5672 times)
Maryam
Sep 26th, 2008, 4:00pm
I am using mtline to model transmission lines. I have provided data file for RLCG from 0-20GHz. I excite the circuit with a 3GHz sinusoid. The transient analysis runs fine, but the pss analysis terminates with an internal error:
"Internal error found in spectre during periodic steady state analysis `pss'. "
"    Segmentation fault."
Does anybody know what the reason of this error or the solution is.
Thank you very much.
Re: PSS Simulation of mtline
Reply #1 - Jan 2nd, 2009, 4:09pm
Assuming you're using a recent build of spectre, you should report this to Cadence Customer Support. Otherwise try a newer spectre version first...
