silentboy wrote on Mar 23rd, 2009, 10:27am:I am running momentum simulation for a differential inductor and got error information:
Found Hole pattern inside hole pattern.
Did you replace a grid of tiny square vias with one large via of equivalent cumulative via ?
Probably there are some vias left from the old array inside the new one and this is mapped on a different layer.
Also see the following.
https://edasupportweb.soco.agilent.com/portal/page?_pageid=36,39953&_dad=portal&...EEsof Knowledge Center > Documents > Support Documents > ADS > Momentum > Simulation
ADS : Momentum : ERROR : More than two segments overlap in geometry. Please modify geometry.
Document ID : 270284
