Oct 31st, 2024, 5:06am
problem about ring VCO ! (Read 128 times)
pllneil
Oct 03rd, 2008, 7:31am
Hi.all.
   I am designing a ring VCO ( 3 invertors ) with cascode biasing.
I get the work frequency Fo=Ibias/(k*Vpp),k is a constant,Vpp is the output swing.Obviously ,the Fo relates to the Vpp,then I think in this case the amplitude modulation is introduced,which will influence the performance of VCO(such as jitter, noise and so on)/.
So what should be considered when it is realized.
I am confused with it ,
Any reply is highly appreciated.  :)
Re: problem about ring VCO !
Reply #1 - Oct 9th, 2008, 12:30pm
You should have no need for cascodes in a ring oscillator. The only thing that gets you is a more ideal current source which is not critical here.
Other than that, a ring VCO is normally buffered  and isolated from its outputs, so I am a bit unsue of the issue at hand. You might want to post your circuits so people can better understand.
Alos, for a good article on ring oscillators circuit architecture, see the PLL paper (IEEE JSSC - around 1995 - 2000) by John Maneatis. (Google it)
Jerry
