jbdavid
I'm going to go out on a limb here, and GUESS that by "without" this circuit, you just had a wire ?
which would mean that you would have had a voltage, and, as needed current along that wire..
with this module you have, effectively an ideal VCVS with the control voltage being the input + offset.. Quite a different thing than
V(in,out) <+ offset;
which defines a branch between in, and out, with a fixed voltage (maybe 0) leaving its current unconstrained.. which will behave MUCH more like a wire..
HTH.
