Oct 31st, 2024, 5:06am
chopping frequency and bandgap bandwidth selection issue (Read 5305 times)
trashbox
Oct 07th, 2008, 1:16am
I'm designing a chopping-op based bandgap such as attachment and I encounter an issue about the selection of chopping frequency and loop bandwidth:
In attachment, bandgap itself's  Loop 1 can suppress the high frequency parts if its bandwidth (open loop unity-gain bandwidth) is lower than chopping frequency. But it will result in bad respondence of chopping signal.
The other way is use Node 1 to suppress high frequency parts with large cap. It seems better.
Which way is better? How to select chopping frequency and bandgap bandwidth? Thanks!
vivkr
Re: chopping frequency and bandgap bandwidth selection issue
Reply #1 - Oct 7th, 2008, 6:31am
You already have the answer to the question. You need to use a large cap at node 1.
Vivek
HdrChopper
Reply #2 - Oct 7th, 2008, 6:43am
Please keep in mind when you chop a system, in order to get accurate gains you need the system's BW to be at least 5-6x larger than the chopping frequency. Otherwise, BW limitation will cause modulated signal attenuations that will show up as gain reductions. Everything outside the chopper can (and needs to) be band limited in order to kill the ripple resulting from the chopper operation.
As vivek suggested, large cap at node 1 is the way out (or decrease the chopping frequency to at least 1/5 of the loop BW). That is your post-chopper filtering means.
Tosei
Keep it simple
trashbox
Reply #3 - Oct 8th, 2008, 10:19pm
Hi Vivek and Tosei !
Thanks for your reply.
trashbox
