Jul 17th, 2024, 2:31am
Jacobian error in Cadence veriloga simulation (Read 2688 times)
gandhi_gaurav
Oct 08th, 2008, 3:29am
I am trying to run a simple simulation to calculate the amount of charge that passes through a simple device and am getting a "jacobian" error.
The code that I am using is very simple as follows:
`include "constants.vams"
`include "disciplines.vams"
module res1(out,in);
inout out,in;
electrical out,in;
real i,charge,finalcur;
analog begin
i= I(out,in);
charge = idt(i);
finalcur = ddt(charge);
The stimulus is a simple voltage source with 1mOhm resistance connected in series to voltage source. This is then applied to the veriloga block I have designed.
and the error that I am getting is zero found in diagonal of Jacobian.
Any guesses what am I doing wrong ?
How can I calculate the amount of charge that is passing through a device ?
Re: Jacobian error in Cadence veriloga simulation
Reply #1 - Oct 9th, 2008, 3:53pm
You need to specify an initial condition for the idt operator.
gandhi_gaurav
Reply #2 - Oct 31st, 2008, 3:40am
Perfect !!
It works !!
