Jul 17th, 2024, 12:16am
concatenate bits into bus in Verilog-A (Read 4327 times)
ssdfz
Nov 03rd, 2008, 7:52pm
Hi everyone:
I created a 5-bit adder in Verilog-A, and when I tried to instantiate the 5-bit adder, FA_5bit, in a larger verilog-A system, I run into the following problem:
FA_5bit i2 (.A(IN[2:0]), .B({ J, K, H }), .CO(CO), .S(S[2:0]), .CI(CI)); HSPICE complains about the concatenation symble "{" saying "syntax error"
The simulation would otherwise go through I change the code as the following:
FA_5bit i2 (.A(IN_SUB[2:0]), .B(IN_SUB[2:0]), .CO(CO), .S(S[2:0]), CI(CI));
Could someone points me where I was wrong?
Many thanks
Erik
patrick
Santa Rosa, CA.
Re: concatenate bits into bus in Verilog-A
Reply #1 - Nov 3rd, 2008, 10:03pm
This Verilog-A feature is not supported in the current HSPICE release (0809). However it is available in the next major release (0903).
Patrick
ssdfz
Reply #2 - Nov 4th, 2008, 8:37pm
Thanks Patrick.
So before the new release, is there any work around? Or I have to split the 3-bit FA into single bit adder adder and connect them together?
