Jul 17th, 2024, 12:19am
Pages: 1 2
About mix simulation for verilog-a and HSPICE (Read 12522 times)
icsoul
Oct 09th, 2008, 9:46pm
When I simulated HSPICE netlist, the simulation result is correct.
Then I added a verilog-a module to simulate with the HSPICE netlist, the result is not correct. But the va module added is just used to test the HSPICE netlist result and not affect the function of HSPICE netlist at all.
Why this happened?
The algorithm has conflict?
patrick
Santa Rosa, CA.
Re: About mix simulation for verilog-a and HSPICE
Reply #1 - Oct 10th, 2008, 7:59am
Assuming the additional VA module does not change the electrical network nor has any $boundstep calls then the addition of this module should not change anything.
If you post the module and netlist we should be able to provide an answer.
Patrick
icsoul
Reply #2 - Oct 13th, 2008, 4:03am
I also think it will not change anything.
But it do changed the simulation result.
Is it the HSPICE bug? I simulated it with version 200606.
The netlist is private, so it can't be upload here,sorry.
patrick
Santa Rosa, CA.
Reply #3 - Oct 13th, 2008, 10:07am
It's hard to help without the netlist or VA file. Try making the VA module really simple - use no ports and just do a strobe like this:
module test_me();
   analog $strobe("Got here");
then instantiate in the netlist as:
x1 test_me
Do the results change now? If not add more statements to the analog block to make it look more like the module that's causing trouble.
Patrick
icsoul
Reply #4 - Oct 14th, 2008, 2:36am
I just included the va module with .hdl and didn't use it.
Even this, the simulation results are also different.
So I think it may be the bug of HSPICE.
Reply #5 - Oct 14th, 2008, 6:26am
What's in your va file?
I remember something about some simulators letting you replace subckts or even built-in models with Verilog-A.  Try changing the name of your module to something really strange that you're sure doesn't exist in your circuit.
patrick
Santa Rosa, CA.
Reply #6 - Oct 14th, 2008, 7:27am
By default, in HSPICE, even if a loaded VA module has the same name as a sub-circuit it will not override that sub-circuit definition. Resolution goes as:
Given an  x instance say,
x1 test_me
Then the system will use the following resolution:
- is test_me a sub-circuit definition?
- is it a model card referencing a VA module?
- is it a paramset or module?
- none of the above => error
Patrick
Tlaloc
Dallas, TX
Reply #7 - Oct 14th, 2008, 9:29pm
I personally have seen non-convergence using HSPICE testbenches that are written in verilog-a.  In this case, I know that there are no name conflicts, nor was I doing anything "crazy", i.e. I was just trying to replace pwl voltage sources.  This did not give reliable results, so I went back to my standard PWL's.  I know that this is not an answer that anyone hopes for, but my experience with HSPICE was to assume that the simulator (while using verilog-a) was screwing something up.
patrick
Santa Rosa, CA.
Reply #8 - Oct 14th, 2008, 9:38pm
If you can post the netlist and VA pwl that's not working I'm happy to take a look.
Patrick
Reply #9 - Oct 15th, 2008, 5:25am
Did you use $bound_step and $discontinuity ?
I still don't understand what could go wrong in icsoul's scenario where he just had the .hdl statement and no instance of the object ...
icsoul
Reply #10 - Oct 15th, 2008, 7:15pm
Geoffrey_Coram wrote on Oct 14th, 2008, 6:26am:
I don't think the reason is your point.
Because I included one va module had a different name with the circuit.
It seems that the Gate Currents are changed when a va module is included.
icsoul
Reply #11 - Oct 15th, 2008, 7:29pm
Tlaloc wrote on Oct 14th, 2008, 9:29pm:
I agree with you,Tlaloc.
The problems I meet are:
1. When I simulated pure circuits, I got one result;
2. When I simulated circuits that just included the va module but not used, I got second result;
3. When I simulated circuits includesd va module and used it, I got another result.
I mean I got three different results in the three conditions.
icsoul
Reply #12 - Oct 15th, 2008, 7:39pm
patrick wrote on Oct 14th, 2008, 9:38pm:
Patrick
Hi, patrick, the following is my va module:
`include "disciplines.vams"
`include "constants.vams"
module divider4 (out, in);
     input in;
     output out ;
     electrical in, out;
     parameter real      vlo=0;
     parameter real      vhi=1.2;
     parameter real vth = (vhi+vlo)/2;
     parameter integer dir=1 from [-1:1] exclude 0;
     parameter real trf=100p from (0:inf);
     parameter real td=0 from [0:inf);
     parameter real ttol=1p from (0:inf);
     parameter integer      ratio=4;
     integer count, n;
     analog begin
           @(cross(V(in) - vth, dir, ttol)) begin
                 count = count + 1;
                 if (count >= ratio) count = 0;
           n = (2*count >= ratio);
           V(out) <+ transition(n ? vhi : vlo, td, trf);
Even  I simulated just two inverters with/without this va module, I got different results too!~ Embarrassed
You can try to simulate any circuits module with this va module.
Of course, the difference is not obvious in this simple circuit. But with more complex circuits, the difference would more and more obvious.
icsoul
Reply #13 - Oct 15th, 2008, 7:43pm
Geoffrey_Coram wrote on Oct 15th, 2008, 5:25am:
No, I didn't use those features.
I'm confused, it is unreasonable at all.
patrick
Santa Rosa, CA.
Reply #14 - Oct 15th, 2008, 10:11pm
Can you run your simulations with the "runlvl" option turned off?,
.option runlvl=0
and see if you still see changes with/without VA.
Pages: 1 2
