Jul 17th, 2024, 12:40am
Pages: 1 2
About mix simulation for verilog-a and HSPICE (Read 12525 times)
Re: About mix simulation for verilog-a and HSPICE
Reply #15 - Oct 16th, 2008, 9:49am
@cross can act to control the timestep, also, which could have some effect on the simulation.
icsoul
Reply #16 - Oct 17th, 2008, 5:13am
patrick wrote on Oct 15th, 2008, 10:11pm:
Can you run your simulations with the "runlvl" option turned off?,
.option runlvl=0
and see if you still see changes with/without VA.
I have tried this option, but it has no help.
icsoul
Reply #17 - Oct 17th, 2008, 5:22am
Geoffrey_Coram wrote on Oct 16th, 2008, 9:49am:
Hi, Geoffrey_Coram
Could you give some advice to avoid this effect?
Reply #18 - Oct 17th, 2008, 7:35am
icsoul wrote on Oct 17th, 2008, 5:22am:
That's sort of a paradoxical request: the cross event is specifically intended to control the timestep such that the crossing time is accurately resolved.
You could change the code so that it samples the voltage and determines for itself whether a rising or falling edge has occurred, but you run the risk of missing an edge.
icsoul
Reply #19 - Oct 21st, 2008, 9:36pm
I got a new version HSPICE and the problem is solved.
Thank all of you!
        icsoul
Pages: 1 2
