Aug 15th, 2024, 11:35pm
Convert Hspice Level 49 Models into Spectre Models (Read 2610 times)
essam
Oct 16th, 2008, 10:15am
Hi All,
I am working on a Switched Capacitor Filter Project. The Professor provided Hspice and TI Spice models only. I want to use Spectre Simulator. Spetre did not recognize the provided Level 49 Hspice models.
Is there a systematic way of conerting Hspice models into Spectre Models?
Essam
Re: Convert Hspice Level 49 Models into Spectre Models
Reply #1 - Oct 16th, 2008, 11:53am
The latest version of Spectre should accept hspice models, you shouldn't even need a simulator lang=hspice statement if it's a .mod or .sp file.
What version of Spectre are you running?
level=49 is bsim3, so
.model nch nmos level=49 ...
should be the same as
model nch bsim3v3 type=n ...
essam
Reply #2 - Oct 16th, 2008, 1:19pm
Thanks for your reply.
I am not sure what version of spectre do we have, and honestly I do not know how to check that.
I attached the model file
Here is the rror message I am getting from Spectre.
Error found by spectre during circuit read-in.
   "/net/core/export/home/ee/001/e/esa061000/Courses/Fall08/hspice_models/HModel5V
1um.txt"
       121: For .model `nch' of type `nmos', the value of level=49 is not
       supported.
1um.txt"
       237: For .model `pch' of type `pmos', the value of level=49 is not
       supported.
1um.txt"
       352: For .model `nat' of type `nmos', the value of level=49 is not
       supported.
spectre terminated prematurely due to fatal error.
Thanks!
Essam
Reply #3 - Oct 16th, 2008, 1:52pm
essam wrote on Oct 16th, 2008, 1:19pm:
It should tell you at the top of the output; you can also do
spectre -W
I'm pretty sure you're using a rather old version.
essam
Reply #4 - Oct 16th, 2008, 1:57pm
I found it: it is spectre er 5.0.33.070605
Essam
Reply #5 - Oct 16th, 2008, 2:06pm
Copy the file and change
.MODEL NCH NMOS
+ LEVEL    = 49
to
(and type=p for PCH)
essam
Reply #6 - Oct 16th, 2008, 2:13pm
I am getting exactly the same error message, after the changes you told
Reply #7 - Oct 17th, 2008, 7:20am
I meant for you to replace 2 lines with one; if you took out the LEVEL=49 line, then you shouldn't be getting the same error message.
essam
Reply #8 - Oct 17th, 2008, 7:40am
That's what I have done but it did not work!!
Essam
essam
Reply #9 - Oct 17th, 2008, 1:53pm
It seems that it reads and interprets the model parameters somehow and based on that say it is Level 49
essam
Re: Convert Hspice Level 49 Models into Spectre Models (SOLUTION FOUND)
Reply #10 - Oct 18th, 2008, 7:15am
HI,
I FOUND THE SOLUTION
Leave the model statement as is:
.Model nch nmos
But remove two lines:
+LEVEL = 49
+VERSION = 3.1
the simulator now runs but I need to check it versus hspice simulation to guarantee that the models are read without problems  :)
Reply #11 - Jan 2nd, 2009, 3:27pm
Bit of a late response, but using spectre from a release in 2003 is probably not the wisest choice... there have been many, many improvements since then, including far better SPICE syntax and SPICE/HSPICE model compatibility. Using an MMSIM70 version of spectre would make far more sense.
