Aug 16th, 2024, 6:15am
Any result browser can read spectre output? (Read 2022 times)
john_ana
Oct 19th, 2008, 9:12pm
Greetings!
I am tired of debugging the bugs in cadence's wavescan. In my opinion, spectre is a very good
simulator but the back-end processing stuff such
as wavescan is kind of shaky and is not stable.
Sometime it works, sometime it doesn't. I am
looking for a robust result browser like awaves.
I know sandwork's SPICE explorer can read
the spectre's output and is very stable. However,
its license is kind of expensive.  Any other tools
can read spectre's output directory?
I am wandering if there is a tool that can convert
spectre netlist to spice netlist. Usually foundry will
provide models for spectre and spice. If I can
get netlist in spicem,  I can run Hspice and use
awaves to plot the results.
Re: Any result browser can read spectre output?
Reply #1 - Oct 20th, 2008, 6:19am
Sandwork was bought by Synopsys last year, I think; since you have other Synopsys tools, you might be able to get a decent price in a VPA for WaveView Analyzer (Spice explorer is something else).
You should also investigate the other output formats of Spectre -- maybe you can find one that  your favorite viewer can read.  (awaves is 2 generations old now; CosmoScope and now WaveView are the "newer" viewers)
Reply #2 - Oct 20th, 2008, 12:47pm
I believe that most people, when confronted with this problem, revert back to AWD.
john_ana
Reply #3 - Oct 20th, 2008, 6:52pm
Ken and Geoffrey,
Thanks a lot for the reply. I am doing a TIA transient simulation and
I ran spectre in standalone mode (no GUI) After the simulation is
done, I use result browser or calculator to plot the output waveform
and do a FFT on the curve.
It is very weird that I can use calculator to plot the waveform, but
when I tried to use the dft function, it says something like:
("strcat" 43 t nil ("Error" strcat argument #1 should either be a
string or symbol ((type template = \"S\" nil))
The expression it calls error on is something like:
dft(v("/SO", ?resultDir "./simulation/test/spectre/schematic/psf" ?result "tran-tran") 20u 1m 65536 "Rectangular" 1 dftCoherentGain ("Rectangular",1))
I did some research on the output format, it seems I can use
options -rawfmt=nutbin,sst2,psfbin,wsfbin etc.
However to read nutbin results, do i need to have nutmeg installed?
any popular result viewer can handle this such as nWave? smartspice?
I also tried to use
simulator lang = spice
.fft V(SO) 20u 1m 65536
However it will report that the .fft card is not currently supported.
My question is how do I plot the fft without resorting to dump the
waveform into a text file? how to invoke AWD?
Reply #4 - Oct 21st, 2008, 5:27am
nutmeg is the output format for Spice3 -- and there are other simulators (eg ADS and Spectre) that can be told to produce it; I've found some differences in their actual file format -- and, of course, some analysis types like PSS or HB that weren't in Spice3 may not have a nutmeg representation.  I would think, though, that your transient analysis would work fine.
I found tools.lnx86/dfII/bin/awd  in my Cadence install.
Frank Wiedmann
Munich, Germany
Reply #5 - Oct 21st, 2008, 6:11am
There have been a number of problems with the new sst2 format, so switching to psfbin might help you, see http://sourcelink.cadence.com/docs/db/kdb/2008/Feb/11422868.html.
jbdavid
Reply #6 - Dec 18th, 2008, 8:29pm
There is also a matlab code for reading psf data..
jbdavid
rf-design
Reiner Franke
Reply #7 - Mar 4th, 2009, 3:13am
Is that the cds2raw.m Matlab script which read psf data into matlab workspace?
I found it under the /spectre/matlab in the MMSIM dir.
Does it work with the default setting from a VADE?
Are there further docs beside the
matlabmeasug.pdf
*.pdf in the IC dir. It is not updated since 2004?
Reply #8 - Mar 4th, 2009, 5:54am
Look in <MMSIMinstDir>/tools/spectre/examples/SpectreRF_workshop/SpectreRF_AN and you'll see MatlabWorkshop.pdf and MatlabAN.pdf which explain how to use it.
Broadly speaking though, you'll need this:
setenv MATLABPATH `cds_root spectre`/tools/spectre/matlab/64bit
setenv LD_LIBRARY_PATH `cds_root spectre`/tools/dfII/lib:`cds_root spectre`/tools/lib/64bit:$LD_LIBRARY_PATH
before launching matlab. The above settings are for if you're running 64 bit matlab; if 32 bit you'd omit the "/64bit" part from the MATLABPATH and LD_LIBRARY_PATH
This ensures that the MATLABPATH is set up OK, and the LD_LIBRARY_PATH contains
the right paths such that the toolbox can load its shared libraries.
The "cds_srr" command (part of the "Spectre Toolbox") can be used to
read all sorts of data from PSF - essentially you call it with:
cds_srr('/path/to/psf/dir'[,'datasetname'[,'signalName']])
and it returns:
1. With 1 arg - the datasets available (same as what you see in results
  browser)
2. With 2 args - the signals in that dataset
3. With 3 args - the data for that signal. This may be a record with (say)
  .V and .time elements, or it may be a matrix if there was some sweeps
The toolbox comes with a bunch of other higher level functions for plotting RF results - these are covered in the app note and workshop PDFs that I mention above.
You don't have to run spectre in any special way to be able to read the results - this reader can read PSF or SST2 simulation results.
