Yawei, You can do this. You need to use "distributed" mode in ADE. This supports the basic "LBS" distributed mode that we ship, LSF, and in later IC5141 versions than the one you're using, SGE. It also supports a "command mode" where you can specify the command to queue the job. In versions such as the version you're using, SGE is also available via a workaround wrapper (ask your hotline support for solution 11015590) if you need this. If you want to be able to just "distribute" onto the local machine, you could do the following: This is all covered in <ICinstDir>/doc/distproc/distproc.pdf Regards, Andrew.
