mitrobgenis
With the following code I manage to read the dwa.txt file with this format
1 0 1 1 0 1 0 0 1 1 1 0 0 1 0 1 0 0 1 1 1 1 1 1 1 1 0 0 0 0 1 1 0 1 1 0 1 0 0 1 1 1 0 0 1 0 1 0 0 1 1 1 1 1 1 1 1 0 0 0 0 1 1 0
`include "constants.vams" `include "disciplines.vams"
module dwa_hdla(Mclk,cs0,cs1,cs2,cs3,cs4,cs5,cs6,cs7,cs8,cs9,cs10,cs11,cs12,cs13,cs14,c s15,cs16,cs17,cs18,cs19,cs20,cs21,cs22,cs23,cs24,cs25,cs26,cs27,cs28,cs29,cs30,c s31);
input Mclk; output cs0,cs1,cs2,cs3,cs4,cs5,cs6,cs7,cs8,cs9,cs10,cs11,cs12,cs13,cs14,cs15; output cs16,cs17,cs18,cs19,cs20,cs21,cs22,cs23,cs24,cs25,cs26,cs27,cs28,cs29,cs30,cs31;
electrical Mclk; electrical cs0,cs1,cs2,cs3,cs4,cs5,cs6,cs7,cs8,cs9,cs10,cs11,cs12,cs13,cs14,cs15; electrical cs16,cs17,cs18,cs19,cs20,cs21,cs22,cs23,cs24,cs25,cs26,cs27,cs28,cs29,cs30,cs31;
integer fid; integer int_cs[31:0];
parameter real vtrans_clk = 1.65; parameter real delay = 0; parameter real rise_time = 1n; parameter real fall_time = 1n; parameter real period = 200n;
analog begin
@(initial_step) fid=$fopen("/home/cadence/dwa.txt","r");
//@(timer(0,period)) @ (cross( V(Mclk) - vtrans_clk, +1 )) begin
$fscanf(fid,"%d",int_cs[0]); $fscanf(fid,"%d",int_cs[1]); $fscanf(fid,"%d",int_cs[2]); $fscanf(fid,"%d",int_cs[3]); $fscanf(fid,"%d",int_cs[4]); $fscanf(fid,"%d",int_cs[5]); $fscanf(fid,"%d",int_cs[6]); $fscanf(fid,"%d",int_cs[7]); $fscanf(fid,"%d",int_cs[8]); $fscanf(fid,"%d",int_cs[9]); $fscanf(fid,"%d",int_cs[10]); $fscanf(fid,"%d",int_cs[11]); $fscanf(fid,"%d",int_cs[12]); $fscanf(fid,"%d",int_cs[13]); $fscanf(fid,"%d",int_cs[14]); $fscanf(fid,"%d",int_cs[15]); $fscanf(fid,"%d",int_cs[16]); $fscanf(fid,"%d",int_cs[17]); $fscanf(fid,"%d",int_cs[18]); $fscanf(fid,"%d",int_cs[19]); $fscanf(fid,"%d",int_cs[20]); $fscanf(fid,"%d",int_cs[21]); $fscanf(fid,"%d",int_cs[22]); $fscanf(fid,"%d",int_cs[23]); $fscanf(fid,"%d",int_cs[24]); $fscanf(fid,"%d",int_cs[25]); $fscanf(fid,"%d",int_cs[26]); $fscanf(fid,"%d",int_cs[27]); $fscanf(fid,"%d",int_cs[28]); $fscanf(fid,"%d",int_cs[29]); $fscanf(fid,"%d",int_cs[30]); $fscanf(fid,"%d",int_cs[31]);
end V(cs0) <+ 3.3*transition(int_cs[0]); V(cs1) <+ 3.3*transition(int_cs[1]); V(cs2) <+ 3.3*transition(int_cs[2]); V(cs3) <+ 3.3*transition(int_cs[3]); V(cs4) <+ 3.3*transition(int_cs[4]); V(cs5) <+ 3.3*transition(int_cs[5]); V(cs6) <+ 3.3*transition(int_cs[6]); V(cs7) <+ 3.3*transition(int_cs[7]); V(cs8) <+ 3.3*transition(int_cs[8]); V(cs9) <+ 3.3*transition(int_cs[9]); V(cs10) <+ 3.3*transition(int_cs[10]); V(cs11) <+ 3.3*transition(int_cs[11]); V(cs12) <+ 3.3*transition(int_cs[12]); V(cs13) <+ 3.3*transition(int_cs[13]); V(cs14) <+ 3.3*transition(int_cs[14]); V(cs15) <+ 3.3*transition(int_cs[15]); V(cs16) <+ 3.3*transition(int_cs[16]); V(cs17) <+ 3.3*transition(int_cs[17]); V(cs18) <+ 3.3*transition(int_cs[18]); V(cs19) <+ 3.3*transition(int_cs[19]); V(cs20) <+ 3.3*transition(int_cs[20]); V(cs21) <+ 3.3*transition(int_cs[21]); V(cs22) <+ 3.3*transition(int_cs[22]); V(cs23) <+ 3.3*transition(int_cs[23]); V(cs24) <+ 3.3*transition(int_cs[24]); V(cs25) <+ 3.3*transition(int_cs[25]); V(cs26) <+ 3.3*transition(int_cs[26]); V(cs27) <+ 3.3*transition(int_cs[27]); V(cs28) <+ 3.3*transition(int_cs[28]); V(cs29) <+ 3.3*transition(int_cs[29]); V(cs30) <+ 3.3*transition(int_cs[30]); V(cs31) <+ 3.3*transition(int_cs[31]); end
