Aug 17th, 2024, 5:14am
frequency divider operating range (Read 987 times)
jlee
Oct 27th, 2008, 8:02pm
Hi guys,
Recently, I have focused on the design of a 10-GHz frequency divider.
I have a question about its operating range.
Why it has a maximum operating frequency? (Due to RC delay?Am I right?)
Why it has a MINIMUN operating frequency? I cannot understand why divider can't work at a lower frequency. Cry
Thanks in advance
Re: frequency divider operating range
Reply #1 - Oct 27th, 2008, 10:49pm
Hi jlee,
I assume you mean a CMOS divider, spicifically it is a CML/SCL divider with resistor load, a divider-by-2.
It reaches the maximum clock rate when the clock period approaches the RC time constant. At that tme, the divider fails.
It has a minimum clock rate because the the circuit will oscillate if the the clock rises/falls slowly.
Please refer to Ullas Singh and Michael Green, Dynamics of High-frequency CMOS Dividers, ISCAS 2002, for the details.
Yawei
jlee
Reply #2 - Oct 28th, 2008, 6:00am
Thank you, ywguo.
It is really a CMOS CML divider.
zwtang
Shanghai, P.R.China
Reply #3 - Nov 4th, 2008, 4:15pm
Hi jlee,
  The problem is similar to the one in digital synchronized circuits. If the clock frequency is high, there will exist setup-up time violations. When the clock frequency is slow, hold-up time is important.
  Please check the critical paths of each DFFS in your CML/SCL dividers.
  Good Luck!
zwtang
