Jul 21st, 2024, 1:22pm
How to simulate charge pump noise? (Read 2707 times)
jlee
Oct 28th, 2008, 8:43pm
Hi guys,
I have following questions about charge pump noise simulation?
1. When I use this charge pump noise to model pll noise, I should use noise PSD (A/sqrt(Hz)) or phase noise (dBc/Hz)?
2. Assume I try to use noise PSD, which simulation I should run by noise, pnoise or others ... ?
Thanks in advance
zwtang
Shanghai, P.R.China
Re: How to simulate charge pump noise?
Reply #1 - Nov 4th, 2008, 4:30pm
Hi jlee
  I think PSD noise should be obtained first from PNOISE analysis. The phase noise contribution from CP equals PSD noise multiplying its transfer function.
zwtang
