Jul 16th, 2024, 3:38pm
Y-parameters in SpectreRF (Read 1070 times)
Paul
Switzerland
Oct 30th, 2008, 1:46pm
It happens I have Y-parameters for a component. I wondered if I can directly use the component as is with SpectreRF or if I have to convert them to S-parameters? Are y-parameters supported in simulation and if yes, how do I tell SpectreRF that these are Y-params and not S-params?
Paul
didac
There's a million
ways to see the
things in life
manresa,spain
Re: Y-parameters in SpectreRF
Reply #1 - Nov 1st, 2008, 5:59am
If my memory isn't failing the nport component supports TOUCHSTONE file format, the first line of that text file has the following description:
# <frequency unit> <parameter> <format> R <n>
in parameter you can specify what kind of data you are introducing(S,Y,Z,H,G).
Hope it helps,
Paul
Switzerland
Reply #2 - Nov 11th, 2008, 12:15pm
Thanks for the input, Didac. It seems there was an issue with the reference impedance definition in the Touchstone file.
Paul
Reply #3 - Nov 19th, 2008, 9:36pm
I don't check Cadence Spectre. But Cadence Spectre should treat Y/Z parameter same as Agilent ADS.
Agilent ADS treats Y/Z parameter in Touchstone and Citi file like followings.
(1) Y/Z parameter in Touchstone
“test_touchstone1.y2p”
! Touchstone for Two-port Y-parameter Data in a single line format
# GHZ  Y  RI  R 50
1.0      11 0  21 0  12 0  22 0
Y/Z parameter in touchstone format are assumed to be normalized by reference resistnace R0.
So actual Yij will be (1/R0)*yij, here R0=Reference Resistance, yij is normalized admittance parameter.
The actual Y- (Z-) parameter value is obtained by dividing (multiplying)
the file entry with the reference resistance.
For example, actual Y11 will be (1/50)*y11=(1/50)*11=0.22, etc…
(2) Y/Z parameter in Citi file
“test_y2p.citi”
CITIFILE A.01.00
NAME SP1.SP
VAR freq MAG 1
DATA Y[1,1] RI
DATA Y[1,2] RI
DATA Y[2,1] RI
DATA Y[2,2] RI
DATA PortZ[1] RI
DATA PortZ[2] RI
VAR_LIST_BEGIN
       4e9
VAR_LIST_END
BEGIN
11, 0
END
BEGIN
12, 0
END
BEGIN
21, 0
END
BEGIN
22, 0
END
BEGIN
100, 0
END
BEGIN
200, 0
END
Y/Z parameter in Citi File format file are assumed to be unnormalized.
