Jul 17th, 2024, 2:19am
Electrical Vs Real (Read 4367 times)
gandhi_gaurav
Electrical Vs Real
Nov 02nd, 2008, 10:24pm
I am designing a block with three inputs v1,v2,v3, one internal node v4 and the one output v5. Now v4 = 1 if (v1+v2+v3) > 3; V4 =0 if (v1+v2+v3) lies between 1 and 2 and V4 = -1 if (v1+v2+v3) <1.
V5 = sin(omega) * v4 where omega is externally specified.
Can anyone help me as how to model these mathematical functions in Verilog-AMS ?
Mainly I am stuck at which to define electrical and which net is real.
-Gaurav
Re: Electrical Vs Real
Reply #1 - Nov 3rd, 2008, 5:36am
Are v1,v2,v3 digital inputs?  You don't specify what v4 is if (v1+v2+v3) is, say, 2.5 (nor, actually, if it's exactly == 1 or == 3), yet clearly v5 is a real-valued output.
jbdavid
Reply #2 - Nov 3rd, 2008, 2:28pm
If this is an osc, you'll need to integrate omega over time to get Phase (phi) and then take sin(phi) ..
this sounds like a variation on a voltage to frequency converter.. ?
my rule of thumb is this..
if the variable needs the spice-like integration (& numerical error) control handled well, make it electrical (or other continuous/conservative discipline).
g'luck!
jbdavid
gandhi_gaurav
Reply #3 - Nov 4th, 2008, 11:20pm
Thanks for the reply.
Let me explain the problem again.
Just trying to realize spice statements like the following into veriloga
.FUNC Q(v1,v2,v3,v4) { (Cg1*v3+Cg2*v4+C1*v1+C2*v2)/E }
.FUNC VN(v) { CSUM*v/E }
.FUNC GAMMA(u) { IF(T==0,IF(u<0,-u,0),IF(u==0,T,u/(EXP(u/T)-1)))}
.FUNC ALPHA(v1,v2,v3,v4) { ROUND(-Q(v1,v2,v3,v4)+(CSUM/E)*(v1*RN2+v2*RN1)) }
In the above statements the function N_OPT calls Function Q, CSUM.
.FUNC R1L(n,v1,v2,v3,v4) {GAMMA(0.5 - n - Q(v1,v2,v3,v4) + VN(v1))/RN1} In the above statement the function R1L calls GAMMA.
Now my query is regarding
> best modeling practice regarding function calling functions  the
> number of values that can be returned If  declarations in functions are real and these cant take values which are defined electrical?
For  example:-
`include "constants.vams"
`include "disciplines.vams"
module setmod2(v1, v2, v3, v4,v5);
inout v1, v2, v3, v4,v5;
electrical v1, v2 ,v3, v4,v5;
parameter real C1=1                     ;
parameter real C2=1                      ;
parameter real R1=1                       ;
parameter real R2=1                       ;
parameter real Cg1=1                     ;
parameter real Cg2=0.1                         ;
parameter real C0=0                          ;
parameter real Q0=0                          ;
parameter real TEMP=4.2                      ;
parameter real  PI=3.14       ;
parameter real  E=1.5            ;
parameter real  KB=1.3             ;
parameter real  CSUM={C1+ C2+ Cg1+ Cg2+ C0}     ;
parameter real  T={TEMP*CSUM*5.3785467E14}  ;
parameter real  RN1={R1/(R1+ R2)}            ;
parameter real  RN2={R2/(R1+ R2)}            ;
analog function real Q1;
input v_1, v_2, v_3, v_4;
real v_1,v_2, v_3,v_4;
Q1 =  (Cg1*V(v_1)+Cg2*V(v_2)+C1*V(v_3)+C2*V(v_4))/(E+Q0) ; endfunction
analog begin
V(v5) <= Q1(v1,v2,v3,v4);
Reply #4 - Nov 5th, 2008, 5:15am
A couple quick points:
gandhi_gaurav wrote on Nov 4th, 2008, 11:20pm:
Ugh!  If you're including constants.vams, why not use `M_PI?
analog begin
Note that the LRM forbids you from using access function references in a function; you should change this to
Q1 =  (Cg1*v_1+Cg2*v_2+C1*v_3+C2*v_4)/(E+Q0) ; endfunction
V(v5) <+ Q(V(v1), V(v2), V(v3), V(v4));
-Geoffrey
Reply #5 - Nov 5th, 2008, 5:17am
There's no N_OPT in what you posted ...
also no R1L ...
