ssdfz
Hi everyone:
I created a 5-bit adder in Verilog-A, and when I tried to instantiate the 5-bit adder, FA_5bit, in a larger verilog-A system, I run into the following problem: FA_5bit i2 (.A(IN[2:0]), .B({ J, K, H }), .CO(CO), .S(S[2:0]), .CI(CI)); HSPICE complains about the concatenation symble "{" saying "syntax error" The simulation would otherwise go through I change the code as the following: FA_5bit i2 (.A(IN_SUB[2:0]), .B(IN_SUB[2:0]), .CO(CO), .S(S[2:0]), CI(CI));
Could someone points me where I was wrong?
Many thanks Erik
