Jul 20th, 2024, 7:25pm
Delta Sigma Problem (Read 2973 times)
tipu
Delta Sigma Problem
Nov 10th, 2008, 4:15am
Hello Everyone
I am working on a BP sigma Delta Modulator and lately got some results that i could not comprehend well.I am showing both the cadence and the matlab results as an attachment file.
The first one is that of matlab
and the second one is of cadence
Now I have 2 questions.
1) It seems that the notch is much sharper in the cadence  as compared to that of matlab.In other words you can say that the cadence results look to do more noise shaping that  the matlab results?? If this is so shouldn't it be the other way around and what is the possible cause of the behavior ?Also there is some difference in the noise floor .It is much flatter in matlab than in cadence
2) The second question is about the SNR calculation. How exactly can i determine the signal bins and the noise bins while calculating the SNR ?
Please Excuse my lack of knowledge in understanding the two things.Any help would be really of great value.
tipu
Re: Delta Sigma Problem
Reply #1 - Nov 10th, 2008, 4:16am
and this one is the cadence result.
fonseca.ha
UK
Reply #2 - Nov 16th, 2008, 9:48am
Are you still strugling with this inconsistency? I am not sure what it may be, but can you give more details? When you say cadence, do you mean a transistor level circuit?
Or do you mean behavioural models?
The issue may simply be the matlab model being too simplistic. But this is just a guess
gaom9
CHINA
Reply #3 - Nov 23rd, 2008, 6:20am
I think you should apply more detail about you simulation. What is your simulation way in cadence, by verilog-A or in transistor level?
View Profile gaom9   IP Logged
