Aug 17th, 2024, 11:56pm
Process insenstitive delay cell (Read 8387 times)
smarty
Nov 11th, 2008, 7:22am
   I wanted to have a process insensitive delay cell. Is there any way we can achieve this. I tried with current starved inverter and thought of controlling the delay with current, but I am unable to achieve delay insensitive to process variation or minimal variation with process.
Can anybody suggest, whether we can achieve the delay insensitive to process variation, if so whether I can get anything in literature.
Thanks and Regards,
SBR
View Profile smarty smarty   IP Logged
Berti
Re: Process insenstitive delay cell
Reply #1 - Nov 12th, 2008, 12:56am
Sure, a delay-locked loop (DLL) can be design to serve as a process-independent
delay-line.
Cheers
smarty
Reply #2 - Nov 12th, 2008, 1:02am
Thanks Berti.
I know this should sound a bit vague, but in any way can we control the delay of a cell over PVT if the delay cell is operate in open loop?.
Thanks and Regards,
SBR
Berti
Reply #3 - Nov 12th, 2008, 7:09am
I don't know.
At least the temperature dependence can probably be reduces when using a PTAT
current.
Cheers
smarty
Reply #4 - Nov 12th, 2008, 7:36am
Thanks Berti...
What I thought was (quite possible I might be wrong also) by using a controlled delay element, like current controlled delay element or VCDL(voltage controlled delay cell), we could achieve reducing the process variation of the delay.
Do you have any thought regarding this.
Thanks and Regards,
SBR
Berti
Reply #5 - Nov 13th, 2008, 6:08am
Sure, but the generation of the control-current (or voltage) that compensates the delay variation will be the real challenge.
Cheers
smarty
Reply #6 - Nov 13th, 2008, 7:42am
Thanks Berti.. I am finding hard as you suggested in generating the control.
With your experience can you suggest any trick by which we can get the control work as needed.
SBR
fonseca.ha
UK
Reply #7 - Nov 16th, 2008, 9:31am
Hi. What is the aplication?
A very accurate way to delay signals by a controled ammount is having a master DLL that generates a control voltage.
After that, the control voltage can be used on a "Slave" delay line in open loop.
A simplier way is if the DLL is digital but you may end up with more jitter.
Another way could with the following:
Using the Band Gap Voltage and a Switched Capacitor Resistor To generate a current.
After use that current (I) to charge a capacitor. The ramp I/C depends only on the ratio of capacitors! so it can be quite accurate!
Alternativelly
Do you have access to a well defined reference current. Perhaps by using an external resistor?
Cheers,
H
Reply #8 - Dec 5th, 2008, 1:56pm
This has been done many times with a PLL or DLL - You have two delay paths, one in the PLL/DLL and the other in the delay path that you are trying to control.
the two delay blocks sit close to each other (same process/temperature conditions) and connect to the same power (same power voltage conditions)
The delay of both the PLL/DLL and the Delay Path are under control of the PLL/DLL feedback system. The PLL/DLL is connected to a reference clock and set to get the desired VCO(PLL) or Delay Line (DLL) time delay needed.
The control voltage tracks out the PVT effects, and you are done.
-- Jerry
neoflash
Mixed-Signal
Designer
Reply #9 - May 6th, 2009, 10:48am
I guess Mr. Smarty is looking for a design which generate a delay like 1ns without using any know reference clock frequency or reference of timing delay.
And he wished to have small variation from process skew and voltage/temperature change.
Right?
smarty
Reply #10 - May 31st, 2009, 8:27am
All,
 Sorry for not able to reply in advance as I was away and had not checked this.
But yes what Mr. Neoflash is saying is to an extent correct. I was trying to generate a delay for which I do not have any reference clock with minimal PV variation.
SBR
