Aug 17th, 2024, 5:22am
UWB bandwidth (Read 1862 times)
aaron_do
UWB bandwidth
Nov 17th, 2008, 6:20pm
just wondering, for a UWB radio, is there any special need to have a flat response (for an LNA for example) over the whole 3-10 GHz bandwidth? My thinking is flat gain (and group delay) is only needed over the channel bandwidth.
thanks,
Aaron
didac
There's a million
ways to see the
things in life
manresa,spain
Re: UWB bandwidth
Reply #1 - Nov 18th, 2008, 1:22am
It's just a question of topology election(I assume you are talking of MB-UWB with channels of 528MHz): if you made a broadband LNA that covers all the bandwidth you don't need to do band selection in the LNA, if you prefer to use a "narrowband"(not so narrow after all) you will need to made typically input and output tunable inductors(like for example stacking inductors, but stacking could change the properties of the inductors).
Hope it helps,
