PalmRunner wrote on Nov 19th, 2008, 9:45am:If the offsets are independent, the total offset should be less than 10 times 1mV, but how much exactly?
Since you are working with statistics, you cannot sum up independent terms. You can sum up the variances, however. To get the answer, you have to take the Root of the Sum of the Squares (RSS) of each independent term. For your case, since all terms have the same sigma value, you total expected offset would be 1mV*√(10).
