Aug 15th, 2024, 1:32pm
Calling Spectre Turbo mode from Ocean Script (Read 1364 times)
Paul
Switzerland
Nov 24th, 2008, 8:41am
Can anyone provide a hint on how to set Spectre to "turbo" mode in an Ocean script? I set the turbo option in ADE, but when I print the settings as Ocean script, there is no trace of this mode. I use CDS 5.10.41 with MMSIM 7.0.1.
Paul
bernd
Munich/Germany
Re: Calling Spectre Turbo mode from Ocean Script
Reply #1 - Nov 24th, 2008, 9:24am
You could try setting the environment variable for the "userCmdLineOption"
in ADE via SKILL at the beginning of your OCEAN script.
envSetVal( "spectre.envOpts" "userCmdLineOption" 'string "+turbo" )
* bernd
Just another lonesome cad guy
Paul
Switzerland
Reply #2 - Nov 25th, 2008, 12:05am
Great input Bernd, works as desired.
Thanks!
Paul
Reply #3 - Jan 2nd, 2009, 8:52am
In more recent IC5141 ISRs (I don't know which subversion you're using), this is now supported - exporting an OCEAN script includes statements such as:
option( ?categ 'turboOpts       'psrFmax  1
        'psrOption  "Default"
        'psrSwitch  t
        'numThreads  1
        'mtOption  "Auto"
        'errorLevel  "Liberal"
        'turboSwitch  t
Rooney
Reply #4 - Jan 5th, 2009, 5:44pm
Can anyone please clarify me the following doubts?
1. What is Turbo mode of spectre? what is the advantage in using that mode?
2. What are the other modes of Spectre? When they are used?
3. Are there any other modes for any other tools?
Reply #5 - Jan 6th, 2009, 1:53am
It adjusts/optimises the algorithms, and simulations (primarily for circuits with a reasonable number of devices) run faster, without compromising accuracy. It also has an improved "liberal" errpreset which is more accurate than standard non-turbo liberal (for transient).
There's also a parasitic reduction option.
Well, this is rather a vague question... however, AMS Designer also has access to the turbo mode (when using spectre as the solver) and Ultrasim will have a turbo mode from MMSIM71 (due shortly).
