tkhan wrote on Nov 29th, 2008, 6:54am:The procfile, actually called _procfile, is in some RAW format which I can not understand.
Usually procfile and p2lvsfile are provided as ascii format.
If you don't have these ascii procfile and p2lvsfile, you can write them by yourself.
procfile and p2lvsfile are easy to wtite if you know thickness of each layer, etc..
You were trying to use Agilent Momentum, so you must know informations enough to write procfile and p2lvsfile.
For a few processes which don't have Cadence Assura RCX environment, I wrote procfile and p2lvsfile by myself.
