Aug 15th, 2024, 10:21pm
wide-band LNA (Read 3500 times)
manfred
wide-band LNA
Dec 05th, 2008, 9:54am
Hi, everyone!
I'm designing a wideband LNA(about 1~1.8GHz) in cascode structure,but  I wonder how to desing the input and output match network?
in my opinion, the input match network can be reallized with LC-ladder(bandpass filter), but I don't know if it is the best way.
as the output of LNA will connect to the offchip SAW filter, so the output match is required. I adopt the emiter follower and output match network, but I think the whole LNA is too complicated and the power is a bit large.
are there any other simple solutions?
anyone is appreciable
Best regards.
aaron_do
Re: wide-band LNA
Reply #1 - Dec 7th, 2008, 5:35pm
for the input matching, have you considered just using resistive feedback, or a common-gate input?
cheers,
Aaron
manfred
Re: wide-band LNA
Reply #2 - Dec 8th, 2008, 3:15am
Aaron:
I have thought about resitive feedback and common-base input, but it seems the NF is a bit large .
so I select the usual structur of source degeneration plus LC-ladder filter .
Have you ever designed resistive feedback or common-base input LNA wich supply good NF performance?
cheers
manfred
aaron_do
Re: wide-band LNA
Reply #3 - Dec 9th, 2008, 5:19pm
i personally have not, but i've read some papers on wideband amplifiers with NF less than 3 dB using those methods. If you want better than that then i guess you will need to go with common-source. Just wondering though, i calculated the Q you require is about 1.67. So perhaps you can just go with a standard inductive source degeneration LNA and still get enough bandwidth.
Not sure if it will help but there is a paper you might find useful if you intend to go for ladder filter design. It used just three inductors total and had a very broad matching bandwidth...
Aly Ismail, Asad A. Abidi, "A 3–10-GHz Low-Noise Amplifier With Wideband LC-Ladder Matching Network" JSSC vol. 39, no. 2, dec 2004.
cheers,
Aaron
manfred
Re: wide-band LNA
Reply #4 - Dec 10th, 2008, 6:37am
thanks Aaron!
your reply is very helpful!
cheers
manfred
