aaron_do
i personally have not, but i've read some papers on wideband amplifiers with NF less than 3 dB using those methods. If you want better than that then i guess you will need to go with common-source. Just wondering though, i calculated the Q you require is about 1.67. So perhaps you can just go with a standard inductive source degeneration LNA and still get enough bandwidth.
Not sure if it will help but there is a paper you might find useful if you intend to go for ladder filter design. It used just three inductors total and had a very broad matching bandwidth...
Aly Ismail, Asad A. Abidi, "A 3–10-GHz Low-Noise Amplifier With Wideband LC-Ladder Matching Network" JSSC vol. 39, no. 2, dec 2004.
cheers, Aaron
