Jul 19th, 2024, 4:30pm
PSS and PAC Analysis (Read 1988 times)
Beginner
Dec 06th, 2008, 2:48pm
I'm currently designing a switched-capacitor (SC) filter. I try to run PSS and PAC analysis in SPECTRE to get the transfer function (H) to verify my gain and 3dB cut-off frequency.
However, the PSS analysis is failed with the following message:
"Attempt to generate initial guess for DC solver failed.
Zero diagonal found in Jacobian at ....."
I try to follow the guide from [http://www.designers-guide.org/Analysis/sc-filters.pdf] where I should set the initial condition of all the capacitors to ZERO & I also set the tstab parameter to 2us (fCLK=1MHz). I also disable the small signal at input (except PAC magnitude =0.1mV at Vin-)
Can anyone tell me what's wrong with my setup?
Thank you so much.
Re: PSS and PAC Analysis
Reply #1 - Dec 7th, 2008, 10:33pm
Zero diagonal is probably due to a floating node. You are probably using overly idealized switches.
