Jul 17th, 2024, 10:36pm
why my D-ff always outputs low voltage? (Read 2635 times)
wwwww12345
Dec 10th, 2008, 8:22pm
  I wrote a verilogA code using "case" for I want to use case sentence in other complex cell. So I wrote a simple DFF as practice.
The code is as follows:
module caseinveriloga(vpa,in,clk);
output vpa;
electrical vpa;
input in,clk;
electrical in,clk;
//output relay;
//electrical relay;
real relay;
parameter real vth=0.5;
parameter real vhigh=1;
parameter real vlow=0;
analog begin
     @(cross(V(clk) - vth, +1) or initial_step)
         relay = (V(in) > vth) ;
      case (relay)
       0: V(vpa) <+ transition (vlow, 1n, 50p);
       1: V(vpa) <+ transition (vhigh, 1n,50p);
       default : V(vpa) <+ transition (vhigh/2, 1n,50p);
      endcase
I send clock and data in every phase, but the output is always low voltage. Who can tell me what is wrong in this code ? Thank you in advance!
BTW, Could anyone tell me how to output a result after 2 clock edge? Thanks !
wwwww12345
Re: why my D-ff always outputs low voltage?
Reply #1 - Dec 10th, 2008, 9:43pm
I knew the reason now. I changed the data type of "relay " to "integer" and the problem is solved. But the question again comes out that how can I compare a 2-bit bus? such as in the code below, it still cannot work well:
module caseinveriloga2(A1,A2,A3,A0,S1,S0,OUT);
// 2-4 MUX
output OUT;
electrical OUT;
input A1,A2,A3,A0,S1,S0;
electrical A1,A2,A3,A0,S1,S0;
integer relay[1:0];
analog begin
         relay[0] = (V(S0) > vth) ;
         relay[1] = (V(S1) > vth) ;
      case (relay)
      00: V(OUT) <+ transition (V(A0), 1n, 50p);
      01: V(OUT) <+ transition (V(A1), 1n,50p);
      10: V(OUT) <+ transition (V(A2), 1n,50p);
      11: V(OUT) <+ transition (V(A3), 1n,50p);
      endcase
I guess the reason why I am wrong is that "relay" cannot equal "00","01", etc. Anyone can help me ? thank you!
Reply #2 - Dec 10th, 2008, 10:59pm
You should almost never put transition functions inside a conditional statement. In addition, you should never use a node voltage as the argument of a transition function.
So you probably need something like ...
 real x;
 case (relay)
     00: x = V(A0);
     01: x = V(A1);
     10: x = V(A2);
     11: x = V(A3);
 endcase
 V(OUT) <+ x;
If you want to switch smoothly between the four signals, then you should use something like this ...
 real m0, m1, m2, m3;
 m0 = 0;
 m1 = 0;
 m2 = 0;
 m3 = 0;
 case (relay)
     00: m0 = 1;
     01: m1 = 1;
     10: m2 = 1;
     11: m3 = 1;
 endcase
 V(OUT) <+ V(A0)*transition(m0, 1n, 50p)
               + V(A1)*transition(m1, 1n, 50p)
               + V(A2)*transition(m2, 1n, 50p)
               + V(A3)*transition(m3, 1n, 50p);
wwwww12345
Reply #3 - Dec 14th, 2008, 11:16pm
Thank you! Ken! I have solved the problem based on your code.
