Aug 15th, 2024, 4:25pm
down-bond (Read 1793 times)
aaron_do
down-bond
Dec 15th, 2008, 11:25pm
I have a receiver design with a RX and a PLL. I'm worried that if the RF section shares the same ground as the digital dividers of the PLL, then a lot of noise will couple to the RF section due to the substrate resistance. So I have the option of down-bonding either the digital divider's ground, or the RF section's ground, and using a separate pin for the other ground. Just curious, which one is better? Should I down-bond the digital divider ground, or the RF section, or should I just connect them both to the down-bond?
thanks,
Aaron
Re: down-bond
Reply #1 - Dec 17th, 2008, 3:09pm
Suggestion: Put together a simplidfied model for this:
Behaviorals with the typical surge currents in the pins/connections and a bonding and package model, with a dummy resistance between the two grounds and investigate your options quantitatively?
Using that you can develop a systematic method to investigate your options.
My guess is that a low impedance grounding structure on both sides will be the best performing, but this will give ypu a method of checking it out.
